Civil 3D Forum
adesetcrdsys?
6 REPLIES 6
sean.keohane
2634 Views, 6 Replies
adesetcrdsys?
In my 2014 version, when I use ADESETCRDSYS a dialogue box appears and I can pick my desired system.
In my new 2015 this appears on the command line. Why is the dialogue box not appearing and how can I fix it?
Command: ADESETCRDSYS
Assign code to: [currentSession/sourceDrawings/eXit]<sourceDrawings>
Regards
Sean
6 REPLIES 6
Jay_B
in reply to: sean.keohane
Try entering CMDDIA @ command line and set it to 1.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
tcorey
Set CMDDIA to 1.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
sean.keohane
in reply to: Jay_B
Thanks For reply,
my cmddia is set to 1.
So it must be something else.
Sean
tcorey
Possibly the Civil 3D 2015 problem with Map support file paths not being created during install.
http://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticle...
Tim Corey
Redding, CA
sean.keohane
in reply to: tcorey
Thank you,
That was the problem.
Regards
Sean
homer028
I have both of those paths in my support paths, so I re-added them at the bottom of the list (as duplicates) and it solved it!
Rail Community
