In my 2014 version, when I use ADESETCRDSYS a dialogue box appears and I can pick my desired system.
In my new 2015 this appears on the command line. Why is the dialogue box not appearing and how can I fix it?
Command: ADESETCRDSYS
Assign code to: [currentSession/sourceDrawings/eXit]<sourceDrawings>
Regards
Sean
Solved by tcorey. Go to Solution.
Try entering CMDDIA @ command line and set it to 1.
Set CMDDIA to 1.
Thanks For reply,
my cmddia is set to 1.
So it must be something else.
Sean
Possibly the Civil 3D 2015 problem with Map support file paths not being created during install.
I have both of those paths in my support paths, so I re-added them at the bottom of the list (as duplicates) and it solved it!
