I need the "create design" panel under the "home" tab but it isn't there. All the help files discuss it as if its there by default and I can't find any way to put it there. Alternatively, typing in the CreateParcelFromObjects command (what I need the create design panel for) in the command line returns a "unknown command" error.
Solved by Civil3DReminders. Go to Solution.
It sounds like you opened AutoCAD as Civil 3D instead of Civil 3D.
Christopher
