Civil 3D Forum
add new layer while in filters
4 REPLIES 4
528 Views, 4 Replies
While I have layer filter on using dialog, I want to add a new layer to this filter.
Normally you right chick and add layer simular to the highlight layer, however, you if layer filter are on, then layer1 is created.
Then you have to find this layer, and rename it.
I also can use the command prompt to created the layer, However, I want to create a layer name simular to the one in the filter, as if I index the layer.  Example:C-topo-spot-existing-phase -1    New layer: C-topo-spot-existing-phase-2.
any suggestion?
4 REPLIES 4
Jay_B
When in a current filter it will not create a new layer within that filter string. The following error message appears if in a filter.
Instead go to "All Layers" Create a new layer C-topo-spot-existing-phase-2 and return to the filter and the new layer should appear in the list of a filter *C-topo-spot-existing* or the likes.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
neilyj666
in each layer filter create a new criteria called Layer* which will get around the problem. do this in your template and never be bothered by it again...
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
rkmcswain
@Anonymous wrote:
Normally you right chick and add layer simular to the highlight layer, however, you if layer filter are on, then layer1 is created.......Then you have to find this layer, and rename it.
I know exactly what you are talking about, I just ran into this a couple of hours ago.
In spite of the workarounds, the implementation of this feature is poor at best.
When you create a new layer, it should create the new layer, immediately put you into Rename mode, then after you have named it, apply the layer filter.
R.K. McSwain     | CADpanacea | on twitter
neilyj666
Yes this is what the expected behaviour should be like
Rail Community
