Civil 3D Forum
accidently unloaded acad.cuix
5 REPLIES 5
mark_cv3d
1810 Views, 5 Replies
Hello!
I was into the command CUILOAD when i accidently unloaded acad.
When i browse for the file acad.cuix and load it then i get a lot of tabs (mesh, section editor.... and o whole lot more)
How do i restore so i can get acad.cuix loaded with only my standard tabs in civil 3d??
Please help me on this one=)
Tags (2)
5 REPLIES 5
Karsten.Saenger
in reply to: mark_cv3d
Hi Mark,
I have quickly tested on my system what happens if the acad.cuix is unloaded and re-loaded. The result is that everything displays as expected. Have you loaded the Civil 3D acad.cuix of the right version?
Before using too much time in troubleshooting the issue you always have the possibility to reset the Civil 3D user profiles to default. This takes 5 Minutes and instructions can be found here:
http://knowledge.autodesk.com/article/Resolving-user-specific-issues-by-resetting-AutoCAD-Civil-3D-2...
Karsten Saenger
mark_cv3d
in reply to: Karsten.Saenger
Thanks for helping.
Can you tell me the standard path to the civil 3d version of acad.cuix? Maybe im in the wrong folder when choosing mine..
Karsten.Saenger
Assuming that you re working with Civil 3D 2014 - for my test I used path
C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\UserDataCache\en-us\Support
Karsten Saenger
dgorsman
Are you sure you unloaded the ACAD.CUIx and not the Civil3D.CUIx?  And how was it loaded - Main, Enterprise, or partial to one of the above?
mark_cv3d
Im sure it was acad.cuix that i unloaded. And it didnt helped to load it from the folder i was given here. But it did help to delete my user settings folders and to reset cad that way.. Strange strange, but now its back to normal again, thanks for helping!
Rail Community
