Civil 3D Forum
acad.pgp not taking priority
10 REPLIES 10
Message 1 of 11
348 Views, 10 Replies
I want to add a custom command to "ss", but adding it to acad.pgp doesn't work. All my other commands work, but for "ss" It seems there is a transparent command "sideshot" which is taking priority.
Anyone know how I can remove the sideshot command?
10 REPLIES 10
Message 2 of 11
Just found the same problem with "dd"
Message 3 of 11
After some considerable googling I found this little nugget:
UNDEFINE
Undefines built in AutoCAD commands. Only works for the current session, so I've added these lines to acad.pgp:
(command "undefine" "ss")
(command "undefine" "dd")
Thanks!
Message 4 of 11
I would wonder if acad is finding a different copy of the acad.pgp file then
the one that your editing. Look at your support paths. The top of the list
takes priority. I would check that you are editing the file found in the 1st
support path.
John Mayo, PE
Core i7 920 6GB DDR3
Radeon 4870HD 1 GB
Vista64
Message 5 of 11
John, I would think these are like "native" commands, they WILL take
priority.
Bill
"John Mayo" wrote in message
news:6335493@discussion.autodesk.com...
support path.
John Mayo, PE
Radeon 4870HD 1 GB
Vista64
Message 6 of 11
I was trying to say this.
Assume acad.pgp exists on the C drive and an identical copy exists on the D
drive.
You edit the version on the C drive but the D drive is listed 1st in the
support paths.
If I am not mistaken, you should not notice the edits because AutoCAD is
loading the acad.pgp file on the D drive.
John Mayo, PE
Radeon 4870HD 1 GB
Vista64
Message 7 of 11
John:
Type either ss or dd in your Civil 3D command line.
Bill
news:6335595@discussion.autodesk.com...
drive.
support paths.
John Mayo, PE
Radeon 4870HD 1 GB
Vista64
Message 8 of 11
Don't worry guys - my issue was resolved with UNDEFINE.
It is in fact a built in command so it's not specified in any other acad.pgp file. This is evident by the fact that UNDEFINE worked, as it only works for built in commands. Had SS or DD been defined in a lisp or any other customisation file like acad.pgp, the UNDEFINE command would not have worked.
Thanks for your efforts!
Message 9 of 11
You can easily tell which file your application is using by typing
(findfile "acad.pgp") on the command line, mine returns this:
"U:\\C3D files\\acad.pgp"
Lisa Pohlmeyer
Williamson County, TX
Civil 3D 2009 SP3 & 2010 SP2
Dell T3400 Quad Core, 2.4Ghz, 4Gb RAM
Nvidia Quadro FX 1700 - Performance Drivers
Message 10 of 11
Hi John,
If you use the [Express Tools][Tools][Command Alias Editor] command,
it's certain you are editing the relevant file.
Laurie Comerford
> support path.
Message 11 of 11
You got a U drive. I have a Yugo is that the same thing. 🙂
Murph
http://map3d.wordpress.com/
"Lisa Pohlmeyer" wrote in message
news:6335810@discussion.autodesk.com...
Lisa Pohlmeyer
Rail Community
