wrote in message
news:6335493@discussion.autodesk.com...
I would wonder if acad is finding a different copy of the acad.pgp file then
the one that your editing. Look at your support paths. The top of the list
takes priority. I would check that you are editing the file found in the 1st
support path.
John Mayo, PE
Core i7 920 6GB DDR3
Radeon 4870HD 1 GB
Vista64
wrote in message
news:6335595@discussion.autodesk.com...
I was trying to say this.
Assume acad.pgp exists on the C drive and an identical copy exists on the D
drive.
You edit the version on the C drive but the D drive is listed 1st in the
support paths.
If I am not mistaken, you should not notice the edits because AutoCAD is
loading the acad.pgp file on the D drive.
John Mayo, PE
Radeon 4870HD 1 GB
Vista64
