Another hint of what I do.. I like to view the surface in 3D and rotate it
around. If you see a blown shot, you save that view to get back in your
drawing window. I then highlight the offending line(s) and make them a
different color. Go back to plan view and you will see where your blown
shot(s) are.
Rick
wrote in message news:5430158@discussion.autodesk.com...
Hey thanks for the responses. By the time I got back to read them I had
found the problem. The surface was fine before I added some breaklines, so
I removed the breaklines until the surface removed the zero elevation and
the contours went back to normal spacing. I then zoomed in on the shoulder
of the road and found that I had two breaklines that were crossing for some
reason. Fixed that and added the breaklines back in and everything is fine
now. After all that THEN I notice that if I would have scrolled up in the
panorama, I would have seen the error and been able to zoom right to the
problem. A valuable lesson, don't just close the window to get it out of
the way, read what it says.
Thanks again,
Daryl
