Civil 3D Forum
Z elevation taskbar
15 REPLIES 15
Message 1 of 16
patrik
1974 Views, 15 Replies
Z elevation taskbar
Hi!
Does anyone know how to show the z-elevation (osnapz) on the taskbar in C3D 2009, AecProject.arx doesn't work for me.
15 REPLIES 15
Message 2 of 16
in reply to: patrik
I have not been able to get it to work either. I believe that using the
AecProject.arx was unintended and it just happened. Someone discovered it.
I know it worked for at least 2 versions. Basically I only used it to be
able to snap to nodes and have my lines (polylines, etc) stay at "0"
elevation. You can do that by going to OPTIONS -> DRAFTING -> checking the
box "Replace Z value with current elevation".
Bill
wrote in message news:5950482@discussion.autodesk.com...
Hi!
Message 3 of 16
AllenJessup
in reply to: patrik
Anything further on this?
Allen
Allen Jessup
CAD Manager - Designer
Message 4 of 16
patrik
in reply to: patrik
No, I'm using osnapz-command.
/P
Message 5 of 16
AllenJessup
in reply to: patrik
I added that to my custom tool pallet. When I have time I'm going to try and make it a toggle. If I succeed I'll post what I have.
Allen
Allen Jessup
Message 6 of 16
in reply to: patrik
I just change it in the options box.
Options -> Drafting -> Select "Replace Z value with current elevation"
There is probably a setvar hanging around somewhere
Bill
wrote in message news:5983785@discussion.autodesk.com...
Allen
Message 7 of 16
AllenJessup
in reply to: patrik
Yes. But I'm doing work where I have to change it frequently. Opening options every time is too cumbersome.
Allen
Allen Jessup
Message 8 of 16
in reply to: patrik
Here's a small LISP I just wrote just for this thread and you guys 🙂
(defun c:zt (/)
(setvar "OSNAPZ" (if (= (getvar "OSNAPZ") 1)
0 ;On
1));Off
(princ (strcat "Ignore Z value is now turned " (if (= (getvar "OSNAPZ") 0)
"ON"
"OFF")))
(princ)
);_defun c:zt
Message 9 of 16
AllenJessup
in reply to: patrik
Thank you! That's what I was aiming for. You've taken one of the round-tuits of my pile.
Thanks again
Allen
Allen Jessup
Message 10 of 16
in reply to: patrik
Good deal. Thanks
Bill
wrote in message news:5983912@discussion.autodesk.com...
(defun c:zt (/)
0 ;On
1));Off
"ON"
"OFF")))
(princ)
);_defun c:zt
Message 11 of 16
AllenJessup
in reply to: patrik
I added the Setvar portion to my Tool Pallet. Happy as a pig in mud.
Thanks again
Allen
Allen Jessup
Message 12 of 16
patrik
in reply to: patrik
How to use the lisp? I'm not used to make my own lisps.
/P
Message 13 of 16
AllenJessup
in reply to: patrik
Copy the text and paste it in to a text editor like notepad. Save it as a file with a .lsp extension. Name it what you want so you remember what it is. Save it in a folder that is search path defined on the files tab of options.
Use the Appload command to load it. If you want it loaded every time. Drag the file to where it says Startup Suite in the lower right of the Appload dialog box.
I've made a button on a tool pallet that contains this:
(setvar "OSNAPZ" (if (= (getvar "OSNAPZ") 1)0 1))(princ (strcat "Replace Z value is now turned " (if (= (getvar "OSNAPZ") 1)"ON""OFF")))(princ)
HTH
Allen
Allen Jessup
Message 14 of 16
patrik
in reply to: patrik
Thanks, now it works for me too.
/P
Message 15 of 16
johngordon6189
in reply to: patrik
2d polylines hold the elevation of the first vertex. you can simple start the line and type .xy, select the node and it prompts for the z elevation, type 0 and that's it. If you are working with lines or 3d polylines, then you would have to use that process at each node.
John
John Gordon
CAD Manager/Survey Technician
C3D 2018/2020
Microstation
Windows 10
Message 16 of 16
AllenJessup
in reply to: patrik
You can also get the .xy and other filters on the Shift = rt-click menu. But I find the OSNAPZ convenient because at times I'll be drawing a bunch of entities that I want at zero then a couple that I want at elevation and back to zero.
Also I don't know if the .xy filter would work in the case where your using the Perpendicular Osnap.
Allen
Allen Jessup
Rail Community
