Civil 3D Forum
Xsect2Surf
15 REPLIES 15
Message 1 of 16
neilyj666
1879 Views, 15 Replies
Xsect2Surf
Anyone know if this has been updated for 2014/2015 (or if it will be)?
http://autodesk.typepad.com/transportation/2012/10/x-section-to-surface.html
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
15 REPLIES 15
Message 2 of 16
Looking at the bundle format (the autoloading system) it should load in 2014 and 2015.
I was able to load it in 2014 using the netload command and selecting the Xsect2Surf2013.dll file, then ran the Xsect2Surf command and the dialogue appeared.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 3 of 16
Cadguru42
in reply to: neilyj666
I've never seen that before. Looks pretty neat.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 4 of 16
Yonas89
in reply to: andrewpuller3811
Just tried to do launch it on 2015 as you told. I have not tried to create the surface but it looks that it is going to work,  because it recognizes command and gives me a wizard.
Message 5 of 16
markus.logdal
in reply to: Yonas89
Yonas89 did you ever get it to work? Im trying to load the application via the NETLOAD command but nothing happens.
Message 6 of 16
Was there any sort of feedback on the command line when you netloaded the Xsect2Surf2013.dll?
Did you run the command Xsect2Surf after netloading the dll?
Andrew Puller
Civil 3d 2021
Message 7 of 16
Nope, nothing on the command line and C3D does not recognise the command XSECT2SURF.
edit: I got NETLOAD to work by adding a couple of lines in the acad.exe.config, however i now get an error when trying the XSECT2SURF. Included the whole error message in a spolier tag.
Spoiler
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.Runtime.Serialization.SerializationException: Unable to load type System.Collections.ObjectModel.ObservableCollection`1[[Xsect2Surf.XSectionSet, Xsect2Surf, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null]] required for deserialization.
at System.Runtime.Serialization.ObjectManager.DoFixups()
at System.Runtime.Serialization.Formatters.Binary.ObjectReader.Deserialize(HeaderHandler handler, __BinaryParser serParser, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage)
at System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream, HeaderHandler handler, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage)
at System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream, HeaderHandler handler, Boolean fCheck, IMethodCallMessage methodCallMessage)
at Xsect2Surf.XRecordAccess.getObjectfromXRecord(ObjectId xsectDictId, Database db)
at Xsect2Surf.XSectionSetEditor..ctor()
at Xsect2Surf.MainXsect.Xsect2Surf()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 20.0.0.0
Win32 Version: 20.0.210.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcdbMgd.DLL
adui20
Assembly Version: 0.0.0.0
Win32 Version: 20.0.51.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/adui20.DLL
AdUiPalettes
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AdUiPalettes.DLL
WindowsBase
Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System
Win32 Version: 4.0.30319.34238 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
Win32 Version: 4.0.30319.34234 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
Win32 Version: 5.2.8.100
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AdApplicationFrame.DLL
AdWindows
Assembly Version: 5.2.10.200
Win32 Version: 5.2.10.200
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AdWindows.DLL
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/accoremgd.DLL
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acmgd.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcWindows.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcCui.DLL
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcWindows.resources.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AeccUiWindows
Assembly Version: 10.4.832.0
Win32 Version: 10.4.832.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/C3D/AeccUiWindows.dll
AeccUiWindows.resources
Assembly Version: 10.4.524.0
Win32 Version: 10.4.524.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/C3D/en-US/AeccUiWindows.resources.DLL
System.Windows.Forms
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AmbercoreEngine
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AmbercoreEngine.DLL
AmberCore.IsdCodecAPI.Core
Assembly Version: 5.0.0.343
Win32 Version: 5.0.0.343
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AmberCore.IsdCodecAPI.Core.DLL
AecMgdReverse
Assembly Version: 7.7.208.0
Win32 Version: 7.7.208.0
CodeBase: file:///c:/program%20files/autodesk/autocad%202015/aca/aecmgdreverse.dll
AecRibbon
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/ACA/AecRibbon.dll
AcMapResourceManagement
Assembly Version: 18.0.301.18
Win32 Version: 18.0.301.18
CodeBase: file:///c:/program%20files/autodesk/autocad%202015/map/AcMapResourceManagement.dll
AcMapLoader
Assembly Version: 18.0.203.3
Win32 Version: 18.0.203.3
CodeBase: file:///c:/program%20files/autodesk/autocad%202015/map/acmaploader.arx
ConvertText
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/map/ConvertText.dll
MapPublishImp
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/map/MapPublishImp.DLL
OSGeo.MapGuide.PlatformBase
Assembly Version: 2.4.0.6216
Win32 Version: 2.4.0.6216
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/map/OSGeo.MapGuide.PlatformBase.DLL
OSGeo.MapGuide.Foundation
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/map/OSGeo.MapGuide.Foundation.DLL
Autodesk.Map.Platform
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/map/Autodesk.Map.Platform.DLL
Autodesk.MapGuide.Studio.Site
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/map/Autodesk.MapGuide.Studio.Site.DLL
AcMapFeatureEntityTooltipsManager
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/map/AcMapFeatureEntityTooltipsManager.dll
ResourceManagerRdfImp
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Map/ResourceManagerRdfImp.dll
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
PresentationFramework-SystemData
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
ManagedMC3
Assembly Version: 8.2.3.0
Win32 Version: 8.2.3.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Map/ManagedMC3.dll
mscorlib.resources
Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_sv_b77a5c561934e089/mscorlib.resources.dll
EmbeddedSQLiteLoader
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Map/EmbeddedSQLiteLoader.dll
AcMapInfoCenter
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Map/AcMapInfoCenter.dll
AeccPartPublishingWizard
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/C3D/AeccPartPublishingWizard.dll
FeaturedAppsPlugin
Win32 Version: 20.0.46.0.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2015/Win64/FeaturedAppsPlugin.dll
C3DVSP3D
Assembly Version: 3.3.0.0
Win32 Version: 2015.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/C3D/C3DVSP3D.dll
AcDialogToolTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcDialogToolTips.DLL
AcDialogToolTips.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcDialogToolTips.resources.DLL
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Anonymously Hosted DynamicMethods Assembly
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcWindows.dll
AeccUiMgd
Win32 Version: 10,4,832,0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/C3D/AeccUiMgd.DLL
AeccPressurePipesMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/C3D/AeccPressurePipesMgd.DLL
AeccContextTabRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/C3D/AeccContextTabRules.dll
AcMapRibbonWrapper
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Map/AcMapRibbonWrapper.dll
AcMapRibbon
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Map/AcMapRibbon.dll
AeccWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/C3D/AeccWindows.DLL
AeccDbMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/C3D/AeccDbMgd.DLL
Microsoft.Expression.Interactions
Win32 Version: 2.0.20520.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Microsoft.Expression.Interactions.DLL
AcLivePreviewContext
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcLayer.resources.DLL
PresentationFramework.Luna
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcAeNet.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcAeNet.resources.DLL
AcCloudRender.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcCloudRender.resources.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcCustomize.resources.DLL
AcDxWizard.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcDxWizard.resources.DLL
AcExportLayoutUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcExportLayoutUI.resources.DLL
AcInterfere.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcInterfere.resources.DLL
AcLayerTools.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcLayerTools.resources.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcMrUi.resources.DLL
AcMultiLineUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcMultiLineUi.resources.DLL
AcRecoverAll.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcRecoverAll.resources.DLL
AcScaleList.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcScaleList.resources.DLL
AcUnderlay.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcUnderlay.resources.DLL
AcViewTransitionsUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcViewTransitionsUi.resources.DLL
AdskConnectionPointMgd.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AdskConnectionPointMgd.resources.DLL
AcCalcUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcCalcUi.resources.DLL
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
AcTaskDialogs
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcTaskDialogs.DLL
AcTaskDialogs.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcTaskDialogs.resources.DLL
AcMrUi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcMrUI.DLL
AcMr
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcMr.DLL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
FeaturedAppsPlugin.resources
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2015/Win64/en-US/FeaturedAppsPlugin.resources.DLL
Xsect2Surf
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/marlog/AppData/Roaming/Autodesk/ApplicationPlugins/Xsect2Surf.bundle/Contents/Xsect2Surf2013.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Message 8 of 16
Looking at the error does not reveal a lot to me, (I'm sure someone with more programming experience can get more meaning out of it) but got me thinking about the versions.
The bundle that is installed with the app include the versions 19.0 - 19.2 for the 2013 dll.
19.0 was 2013, 19.1 was 2014.
2015 though is version 20.0 which generally means that apps made for the previous major version, being 19 will not work.
Unfortunately I think this means that xsect2surf nees to be recompiled for 2015 in order for it to work.
So I think you are going to have to contact the developer on the link posted early where the tool comes from.
Andrew Puller
Civil 3d 2021
Message 9 of 16
I've installed and succesfully used the application on another computer running C3D 2015 as well, so the error is on my end. I've tried reparing, uninstall ingand reinstalling everything, ranging from civil3D to .NET frameworks. But I still get the same error.
Message 10 of 16
Krite1
in reply to: markus.logdal
Look at the properties of the .dll file in explorer and see if there is an unblock button. If so unblock the file and reload.
I successfully loaded the file on Civil 3d 2015.
Message 11 of 16
cjkiefer02
in reply to: Krite1
We were using it also and it seems to be something with service pack 2.  We have a computer with service pack 1 and it is working but my computer has #2 and it will not run.
Message 12 of 16
markus.logdal
in reply to: cjkiefer02
I uninstalled service pack 2, and voila it works! Thanks cjkiefer02
Message 13 of 16
cjkiefer02
Curious if anyone has got this tool to work with Service Pack 2.
Message 14 of 16
Try this post here
http://forums.autodesk.com/t5/autocad-civil-3d-general/xsect-2-surf/m-p/5504246/highlight/true#M2676...
Neilyj posted a zip file with a 2015 specific version.
Andrew Puller
Civil 3d 2021
Message 15 of 16
michelsurveyor
Dear support,
I hope this email finds you well.
I am writing to ask about Xsect2Surf tool .
Please can you send me the link to download it.
Thank you and best regards
Message 16 of 16
neilyj666
in reply to: michelsurveyor
Refer to post 14 above - this tool may or may not work and is unsupported.
This is a peer to peer forum and as such does not provide support
Rail Community
