Civil 3D Forum
Xref fade not working on arcs or circles
8 REPLIES 8
Message 1 of 9
stevebatchelder
1291 Views, 8 Replies
in Civil 3D 2012, the fading isn't working on arcs or circles for both layer lock fade and xref fade. This is only happening on my machine because I opened the file on two other machines in the office and the fade worked as expected.  Is there some setting that would be causing this to happen? Is it something to do with my video card?
We just recently upgraded from C3D 2009 to 2012 and the layer lock fade works as expected in 2009. See attached picture.
-Steve
Steve Batchelder
Civil 3D 2018, Infraworks 2019
8 REPLIES 8
Message 2 of 9
Hey Steve,
I am aware of these 3 system varaibales.  You already mentioned two but I would suggest you try the XFADECTL too. Here they are (copied from help):
  • LAYLOCKFADECTL - Controls the amount of fading for objects on locked layers
  • XFADECTL - Controls the amount of fading within a reference being edited in place. This setting affects only the objects that are not being edited in the reference
  • XDWGFADECTL - Controls the dimming for all DWG xref objects
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 3 of 9
Hi Almas,
I drew some arcs and circles in the drawing with the xref in it and did the in-place xref editor. It seems to fade all the non-xrefed objects as it should. It also works as expected for the in-place block editor.
One thing I recently discovered was that if a assign a non-zero width to a polyline, the arcs will be faded in both the xref and layer lock scenarios. Very peculiar.
Steve Batchelder
Message 4 of 9
If WHIPARC = 1 then set it to 0.
Allen
Allen Jessup
CAD Manager - Designer
Message 5 of 9
That worked! Thanks Allen!
Steve Batchelder
Message 6 of 9
You're Welcome. A very weird system-variable that.
Allen
Allen Jessup
Message 7 of 9
Joe-Bouza
in reply to: AllenJessup
WHIPARC?
You should get a free ride to A.U. Smiley Wink
Your Name
Message 8 of 9
AllenJessup
in reply to: Joe-Bouza
WHIPARC was a nice idea. But you could never plot arcs or circles the right color, unless the color of the arc was the color you wanted to print. So on B&W prints you'd have color arcs! It's been broken since it was introduced about 10 years ago. It's a relative of WHIPTHREAD.
Allen
Allen Jessup
Message 9 of 9
rkmcswain
FYI: still broken in 2015.
R.K. McSwain     | CADpanacea | on twitter
Rail Community
