Valued Contributor
shinysingh
Message 1 of 5 (365 Views)
Xref Lines are not showing
365 Views, 4 Replies
01-10-2013 08:02 AM
Hello There,
I have x'ref a dwg. file in my current drawing. And when i print preview with the correct ctb style... The x'ref lines are not showing up?
Can anyone tell me how can i fix this? I have pretty much tried everything...
I am having troubles showing the green, cyan and yellow color. when i print preview it doesnt show nothing. The true color is on RGB.
Valued Contributor
shinysingh
Message 2 of 5 (357 Views)
Re: Xref Lines are not showing
01-10-2013 08:22 AM in reply to: shinysingh
Can anyone please help me ASAP..
jmayo
Message 3 of 5 (354 Views)
01-10-2013 08:25 AM in reply to: shinysingh
Does the xref reside on a layer that is set to NoPlot (like the defpoints layer) or on a layer that is frozen in that specific viewport (vpfreeze variable)?
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Valued Contributor
shinysingh
Message 4 of 5 (353 Views)
01-10-2013 08:26 AM in reply to: shinysingh
Never mind, i found the solution. when i xref the file, i selected the no plot layer. that's why it wasn't showing up in print preview...
Valued Contributor
shinysingh
Message 5 of 5 (352 Views)
01-10-2013 08:29 AM in reply to: shinysingh
Yes, you are right, John. I was on wrong layer. Thanks
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
