Hello There,
I have x'ref a dwg. file in my current drawing. And when i print preview with the correct ctb style... The x'ref lines are not showing up?
Can anyone tell me how can i fix this? I have pretty much tried everything...
I am having troubles showing the green, cyan and yellow color. when i print preview it doesnt show nothing. The true color is on RGB.
Solved by shinysingh. Go to Solution.
Does the xref reside on a layer that is set to NoPlot (like the defpoints layer) or on a layer that is frozen in that specific viewport (vpfreeze variable)?
John Mayo
Never mind, i found the solution. when i xref the file, i selected the no plot layer. that's why it wasn't showing up in print preview...
