Is there a way to revert back to the original colors of an xref besides having to reattach the xref and purging the DWG.
I always change the colors of the projects Existing site/utilty XREF to color 252 to shade it back to have the proposed show up darker. But I try to select all layers to change the colors back to what they were before and the box to set color by layer is not available.
Thank You
Solved by troma. Go to Solution.
Solved by Jay_B. Go to Solution.
Solved by Ed.McGriskin. Go to Solution.
Temporarily set VISRETAIN to zero.
Reload the Xref's you want to inherit the Xref drawing color settings.
Change visretain back to 1 so any additional color assignments in current drawing are maintained.
Mark Green
Working on Civil 3D in Canada
Another option I have sometimes used it to set the colours for some objects individually, not ByLayer. Typically I will do this if it is something simple that I need to change the colour of, and I don't want to go through 15 drawings changing the layer colour or messing with VISRETAIN. If you do the colour this way it will automatically propagate to all drawings that reference it—because the colour is not ByLayer it ignores the colour setting for the layer in the host drawings.
Mark Green
@Anonymous expand out the dialog box and choose the setting you want to use before hitting 'Save'
Mark Green
Just Had this problem using FDOT Template
To change this setup, go to Layer Properties, click on setting right at the upper right corner of the window and change xref layer settings from don't retain overrides to refer layer properties to retain overrides.
I think this is what you are looking for (link below, post #10):
https://forums.autodesk.com/t5/civil-3d-forum/visretain/m-p/9207520/highlight/true#M413377
It is a function called 'Reset Xref Layer Properties' and is a quick way to reset xref layer properties to those of the base drawing, without affecting viewport overrides (something VISRETAIN can't currently accomplish in any state).
Check it out and let me know if it helped you!
This solution doesn't appear to work in CAD version 2018 - but I found something that does.
I opened a blank CAD file and xrefed my base into it and then created a layerstate from this file in modelspace (note: no overrides in the layerstate). I exported that layerstate. Then open my original file that has the xref with layer colours overriden. In modelspace, I import the new layerstate I just created.
And voila - my modelspace is correct again, but all of my viewport overrides stay as is. It's kind of annoying, but simpler than the VISRETAIN route where I have to re-freeze layers and fix layerweights etc in every viewport ever.
In the layer properties manager, expand Xref node, right click the file you want to revert back to original colors, hover over Reset Xref Layer Properties, select Color. The colors will revert back to original colors assigned in the Xref file. Just discovered this myself, very simple after all!
