AutoCAD Civil 3D General
Active Contributor
Message 1 of 6 (183 Views)
Xref Label Alignments
183 Views, 5 Replies
04-29-2013 09:31 AM
Hi there Civil 3d users,
I am currently trying to xref a Civil 3d files into auto cad 2d. So far on the model space it works fine however when i try to put it into paper space the labels on the profiles just seems to go crazy. See the attached picture. (First picture where the label are not displaying correctly in paper space and second drawing in model space of the same drawing which shows the labels correctly).
I beleive its the annotation that civil 3d uses to generate these text labels but i am unaware of how this can be solved. I would greatly appreciate if someone could shed light on this.
Jeff_M
Message 2 of 6 (153 Views)
Re: Xref Label Alignments
04-29-2013 11:21 AM in reply to: karen.woodward
Set the scale in the Viewport to your desired scale, regen.
Active Contributor
Message 3 of 6 (120 Views)
04-30-2013 03:29 AM in reply to: Jeff_M
Jeff,
Thanks for the reply, i wish it was that simple. I should have mentioned this before on the post>I have tried this method and it is not working
Any other ideas. :smileyhappy:
Jay_B
Message 4 of 6 (115 Views)
04-30-2013 04:48 AM in reply to: karen.woodward
What is the MS scale of the Xref?
What is the VP scale set to?
Have you verified the various Annotative system variables are properly set?
Do the drawing Units match in each dwg?
Jay
C3D 2012 SP3 & C3D 2014 SP1
Win 7 Professional 64 Bit
Active Contributor
Message 5 of 6 (109 Views)
04-30-2013 05:08 AM in reply to: Jay_B
Thanks for the reply, Jay ,
Not quite sure of some of the things you have mentioned. I guess it is pretty basic but shedding some ligght on this would be greatly appreciated.
What is the MS scale of the Xref?  Again not sure why would this be of any help. As i beleive I am just setting up the scale in VP not model space, Please correct me if I am wrong.
What is the VP scale set to? VP scale is set to 1:500
Have you verified the various Annotative system variables are properly set? Not sure what you mean by this. How can i do this.
Do the drawing Units match in each dwg? Yes
Message 6 of 6 (95 Views)
04-30-2013 05:52 AM in reply to: karen.woodward
Units here need to match your paperspace units:
Credit where credit is due! Give kudos or accept as solution whenever you can.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
