Civil 3D Forum
XRef shading for visibility....Need to see the XREF....Help!
5 REPLIES 5
14196 Views, 5 Replies
Every time I attach an XREF file, the xref drawing is shaded and is very difficult to see.  Please help this frustrated Surveyor that is not a happy camper, having looked through a good deal of the COMMANDS & properties trying to make Xref's more visible, without binding them into my original drawing.  Thanks!
5 REPLIES 5
michael.robertson
xdwgfadectl controls the amount of fading (0 for no shading, upto 90 for almost invisible).
You can also use TRANSPARENCYDISPLAY to set whether transparency are displayed or ignored.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
in reply to: michael.robertson
Thanks, Michael!  That did the trick!
ODG
tHERE IS ALSO A SLIDER IN THE OPTIONS as of 2010 to control this.
Can you tell me what tab this is under in the options?
Ok.
I found it.  It was under the Display Tab
Located in the lower right under Fade Control
Set the Xref Display to 0
Rail Community
