I never did figure out what caused that. Crazy thing was that I only ran into this issue on 2 projects, where I could not see the labels when opened on any PC in my office. But when I sent the files for others to see what I was, they thought I was nuts because the labels all showed up fine for them. Since moving to C3D2012 last year I have not had this problem...but I never thought to check if that original dwg would now work correctly in 2012. (That project died before completion due to the client filing bankruptcy.) So I just found the file that would not show the labels, loaded it into 2012...all those labels that 2010 refused to display now show up fine.
So I guess that's some almost scientific proof that whatever was broke is now fixed. Not that it does much good if you are still stuck with 2010, other than give you some ammunition to fight for an upgrade.
Jeff,
Thanks for the update. I believe we are going to upgrade, but I think it will coincide with new hardware and upgrading the OS (we're still on XP), so I'm not sure what the timing is. In the meantime I'll just try to keep track of the labels and make sure none "disappear".
Just keep in mind that most of that extra information will get lost if you ever have to edit your Parcels. As opposed to Map 3D topolgies, here's no "centroid" concept in Civil 3D Parcels, so editing Parcels can cause them to "forget" lots of useful data. Very annoying, when the problem affects you. But there ARE situations where you don't really hit it, and can get by OK. Luck of the draw, I suppose.
