Valued Contributor
pserpas
Message 1 of 8 (1,744 Views)
XREFs will not display
1744 Views, 7 Replies
09-13-2011 05:42 AM
Many times when I try to attach a xref and do a zoom extents, I cannot find the drawing.  I change my limits to -999999,-999999 and 999999,999999 but still nothing.  This seems to be a random problem.
Pat
Windows 7 x 64
Nvidia GeForce GTS 450
8 GB Ram
Intel Core i5-2310 @ 2.90 GHz
v. F.107.0.0 AutoCAD Civil 3D 2012 SP1
Strakan
Message 2 of 8 (1,716 Views)
Re: XREFs will not display
09-13-2011 10:34 AM in reply to: pserpas
Two things I can think of:
Check to make sure your XREF is on the zero Layer or
Type Options, and under the display tab, turn your XREF fade control to -90.
Jeff_M
Message 3 of 8 (1,711 Views)
09-13-2011 10:44 AM in reply to: pserpas
If you have drawing A with C3D objects in it (such as a Surface), you then open drawing B and Xref A as on overlay. Now add some surface labels for the xref'ed surface in A. If you now try to Xref B into a drawing C, you will have broken labels sinc ethe overlay'ed drawing A is not available for the Labels in B to update from....make sense? So now in C you will have these "broken reference" labels all at 0,0, and if the drawings themselves are at normal State Plane coordinates of say 300,000/1,000,000 then a zoom extents will not appear to display anything since these objects will be too small to see. Try selecting with a crossing selection near 0,0 and you will likely find the culprit.
New Member
bdevineni
Message 4 of 8 (1,366 Views)
01-04-2013 10:16 AM in reply to: pserpas
I do have the same trouble. I have a drawing "A" with limits 0,0 to 36,24. I am trying to attach this drawing to a layout of dwg "B". I can see it in reference diaglog box, but I dont find it in layout. I checked all other options like layer on, fade -90, everything is ok. I did quickselect xref and It is selecting the ref "A" with a grip point at 0,0. But I dont see it.
However, I had xrefed again in model. I find it attached at different location coordinates -2960277.4188,-13825882.14. But the insertion point in properties shows me 0,0,0 and scale as 1.0.
Can anyone suggest me how to correct this bug?
troma
Message 5 of 8 (1,361 Views)
01-04-2013 10:38 AM in reply to: bdevineni
Welcome to the forums.
You're generally better off starting a new thread than adding to an old one with a new question.  I don't think your problem is related.  You can't x-ref a drawing into a layout, paperspace, as far as I know.  Try inserting it as a block instead.
I don't quite follow the problem you had with x-reffing into model.  Let me ask you: is drawing A drawn in model or paper?  You can only x-ref what is in the model space.
Credit where credit is due! Give kudos or accept as solution whenever you can.
New Member
bdevineni
Message 6 of 8 (1,352 Views)
01-04-2013 11:50 AM in reply to: troma
Actually we can xref a drawing A (which is drawn in model) to paperspace of dwg B. I always do that for titleblock.
The drawing which I draw is in model space with limits 0,0 and 36,24. When I xref it in dwg B - it is not inserting at 0,0. It is inserting at -2960277.4188,-13825882.14. which is far away. I units are matched, which is feet (both dwgs). I dont know why it is not inserting at 0,0.
Joe-Bouza
Message 7 of 8 (1,351 Views)
01-04-2013 11:51 AM in reply to: troma
Yes you can. I do it all the time for key maps.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
troma
Message 8 of 8 (1,347 Views)
01-04-2013 12:07 PM in reply to: Joe-Bouza
Well there you go, always something new!
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
