AutoCAD Civil 3D General
Active Member
brandon.nittler
Message 1 of 8 (277 Views)
Working Space versus Model Space
277 Views, 7 Replies
02-27-2013 01:29 PM
Trying to figure out what the difference is in the different tabs on the CAD Civil 3d 2012 program. I understand the difference between model space and paper space, but what is the new working space for (it is its own little tab at the bottom)?
Thanks in advance!
*Pro
dgordon
Message 2 of 8 (263 Views)
Re: Working Space versus Model Space
02-27-2013 01:44 PM in reply to: brandon.nittler
workspaces provide one with a whole new set of ribbon commands.   I have to switch to a map ribbon to use the map image insert command from the ribbon because it doesn't exist in the C3D ribbon.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Valued Contributor
HansSMS
Message 3 of 8 (261 Views)
02-27-2013 01:46 PM in reply to: brandon.nittler
Workspace is the environment you set yourself up to work in, i.e all the menu items, toolbars and ribbon settings you customize for yourself. You can set up different workspaces for different types of work. Switch through the various default workspaces provided and you see what I mean. You can create your own by duplicating an existing one and tweaking it, then saving it under a different name. Workspaces have nothing to do with your model and paperspace systems you work in.
Hans Moller
Surveying & Management Services
Gladstone Australia
Clevo Metabox 16GB, Intel i7-3720QM 3.1Ghz, 256GB SSD, Nvidia GTX 680M
AutoCAD Civil 3D 2013
Active Member
brandon.nittler
Message 4 of 8 (256 Views)
02-27-2013 01:50 PM in reply to: HansSMS
It is kind of confusing what I am getting at. Its not like a workspace that I set up for different projects, these are actually tabs located at the bottom of the screen.
In previous versions there were a couple of different tabs (or spaces) that you could work in, Model Space (tab) and Paper Space (tab).  In this version that I am now operating under they have added a third tab called "Working."
I am having trouble determining what the purpose of this tab/space is when it comes to linework.  Is there an advantage/disadvantage to using this tab for doing work? Certain scenarios that one would or wouldn't use this tab, etc...
Overall what is the prupose of the tab if I go into it?
troma
Message 5 of 8 (248 Views)
02-27-2013 01:59 PM in reply to: brandon.nittler
Can you give a screen shot of this tab?  Seems like no-one knows what you're talking about.  I've never seen it, but I'm in 2011.
Is it possible that a third-party app is giving you this tab?
Credit where credit is due! Give kudos or accept as solution whenever you can.
mathewk
Message 6 of 8 (246 Views)
02-27-2013 02:00 PM in reply to: brandon.nittler
Attach an image so we can see. By your description it sounds like just another paper space layout named "Working", the purpose of which would be up to the person who created it.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Product Support
phil_borycens
Message 7 of 8 (185 Views)
03-05-2013 03:12 PM in reply to: brandon.nittler
As already pointed out, this is either another Layout tab simply named "Working", or something that is coming from a 3rd party add-on to AutoCAD Civil 3D.
MODEL and PAPER are the only 'spaces' that come with AutoCAD-based products.
While in a Layout tab, if you double-click inside of a viewport, you are brought back into MODEL space. If you double-click outside of the viewport, you are returned to PAPER space.
Phil Borycens
Active Member
brandon.nittler
Message 8 of 8 (181 Views)
03-05-2013 03:15 PM in reply to: phil_borycens
That is pretty well all I can figure. I do not know what it is, but nothing that I have seen when searching has brought up any response in answer to what this "space" is.
Appreciate the feedback.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
