Distinguished Contributor
GreeneSWCD
Message 1 of 6 (129 Views)
Work flow for Earthwork Options in the same place?
129 Views, 5 Replies
05-09-2014 07:11 AM
I'd like to design a few different options for an earthen berm in the same spot.  How do I keep them all separate?  For instance, I'd like to have a hill at different heights along with different side slopes.  I thought I'd just use different surfaces, but even when I turn the surfaces to no disaplay, I still have my feature lines staying put.
My goal is to build sheets showing each hill option with an earthwork computation for each option.  I'm sure this is a simple endeavor, I'm just looking for a way to keep it clean.
I'd like to do each option in its separate site, and then just be looking at one site at a time.  Is this possible?
Valued Mentor
awood
Message 2 of 6 (112 Views)
Re: Work flow for Earthwork Options in the same place?
05-09-2014 09:12 AM in reply to: GreeneSWCD
How about Data Referencing the design surfaces into seperate drawings/sheets for plan production?
HTH
AWood
GreeneSWCD
Message 3 of 6 (108 Views)
05-09-2014 09:36 AM in reply to: awood
I've never data referenced before, could you point me to a tutorial or walk me through here?
Valued Mentor
awood
Message 4 of 6 (103 Views)
05-09-2014 09:59 AM in reply to: GreeneSWCD
It's actually a pretty simple process, similiar in idea to external references (XREFs).
There are in-software tutorials to guide you through the process.
http://docs.autodesk.com/CIV3D/2012/ENU/filesCTU/GUID-68AC7599-F635-4391-9F9A-6E9EF96F9ED-102.htm
HTH
AWood
neilyj
Message 5 of 6 (92 Views)
05-10-2014 12:46 AM in reply to: GreeneSWCD
You could also make copies in the same dwg and displace by an appropriate amount and if you put the feature lines on different layers these can be frozen as needed in viewports etc. Same goes for surfaces - add a name suffix for the main surface object in settings and the surface can be frozen in viewports
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Joe-Bouza
Message 6 of 6 (82 Views)
05-10-2014 06:13 AM in reply to: GreeneSWCD
all good suggestions. This was a question only a few days ago you may find interesting >>>HERE<<<
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
