AutoCAD Civil 3D General Discussion
Active Contributor
rwhitlock
Message 1 of 3 (55 Views)
Wish List
55 Views, 2 Replies
04-02-2004 10:24 AM
I would greatly appreciate the addition of a civil 3D routine whereby Point data can be added directly to roadway features (top of curbs, etc,) by reading the elevation data from a road grid defined by a template. For example, I've been using a third party app. which will allow the placement of top of curb elevations anywhere along an alignment defined by a road template. Incredibly useful!
*Zdenko Novkovic
Message 2 of 3 (55 Views)
Re: Wish List
04-05-2004 08:21 AM in reply to: rwhitlock
Sounds like point codes in the design center of LDD for cross sections.... Z "rwhitlock" wrote in message news:21125374.1080930284758.JavaMail.jive@jiveforum1.autodesk.com... > I would greatly appreciate the addition of a civil 3D routine whereby Point data can be added directly to roadway features (top of curbs, etc,) by reading the elevation data from a road grid defined by a template. For example, I've been using a third party app. which will allow the placement of top of curb elevations anywhere along an alignment defined by a road template. Incredibly useful!
Active Contributor
apence
Message 3 of 3 (55 Views)
Re: Wish List
12-02-2004 11:49 AM in reply to: rwhitlock
When you import an alignment from Land Desktop it is not very easy to edit it. In fact, it seems that you loose most of the Horizontal alignment editing functionality of Civ3D.
Land Desktop knows where PI's are for horizontal alignments. It would be nice if Civ3D would allow you to import the curve PI's of the alignment instead of just the curves.
As it is now, grip editing an imported curve changes the curve radius, but the endpoints stay the same. So, if you edit the curve, then the tangents are no longer tangent to the curve. It would be nice to have the option to import an alignment as if it was created with the tan-tan layout tool with curves added later. Then, adjusting the curve would adjust the PC and PT accordingly. You would also be able to grip edit the curve PI as well.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
