I am having problems with the point stylw with my cogo points. We have created a series of blocks (previously from LDD) that worked with the description keys just fine. When we assign them as a point style, the wipeouts from the blocks keep coming over the top of the information. If I were to just insert the block, it works as intended. the image below shows the inserted block, while the cogo point to the right is how it shows up when assigned as a point style. I have tried redefining the block several times in the drawing and from the original source to no avail. Does anyone have a fix for this? We use wipeouts quite a bit.
Chris M. Davis
Survey Tech
Solved by mathewkol. Go to Solution.
Edit the block in the block editor.
Copy everything except the wipeout from 0,0 to 0,0.
Erase Previous.
Save and close the block.
Hopefully this works.
So far this did work, thank you. Now I have to go through all my blocks and do this..(ugh)
Thanks again,
Chris
I struggled with this for a long time. This solution worked! Thanks for your help!
Glad it works for you.
