AutoCAD Civil 3D General
neilyj
Message 11 of 21 (267 Views)
Re: Why does my linetype change if i rotate passed 180 degrees?
11-01-2012 12:45 PM in reply to: cadman33619
I can't get this to work at all...:smileyfrustrated:
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
AllenJessup
Message 12 of 21 (262 Views)
11-01-2012 12:54 PM in reply to: neilyj
If either of you want to email me a jessupa at co.rockland.ny.us I'll send both files to you.
Attached is a file created in 2012 and saved to 2007 with the linetype shown in it.
Allen
Distinguished Contributor
cadman33619
Message 13 of 21 (259 Views)
11-01-2012 12:59 PM in reply to: AllenJessup
i see..
ok im getting bad definition on line 2. i copied yours exactly.
AllenJessup
Message 14 of 21 (251 Views)
11-01-2012 01:15 PM in reply to: cadman33619
I've reviewed the creation of custom linetypes from the 2012 help files. The only difference I see is that they now specify the the .SHX extension. Like this:
*FENCEX,Fence with Xs
A,1.0,-0.09848,[FENCEX,FenceX.shp,s=.05],-0.09848,1.0
I also see that in the original post I said to rename the the file to a .SHP file. It should be a .SHX file.
Allen
neilyj
Message 15 of 21 (246 Views)
11-01-2012 01:56 PM in reply to: neilyj
Still no luck - I'll try again tomorrow with fresh eyes...
neilyj
Distinguished Mentor
andrewpuller3811
Message 16 of 21 (235 Views)
11-01-2012 06:57 PM in reply to: neilyj
you need to compile the shp file first.
In autocad type "Compile" (without the quotes) on the commandline
Locate and select the fencex.shp file and click open.
The command line should show this
"Compiling shape/font description file
Compilation successful.  Output file D:\My Documents\Cad\AWP Cad Setup\Line Types\FenceX.shx contains 100 bytes."
Using windows explorer, copy the resulting FenceX.shx file into a folder in your support path.
Back in autocad, load the linetype from the FenceX.lin file.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
neilyj
Message 17 of 21 (213 Views)
11-02-2012 01:53 AM in reply to: andrewpuller3811
Thanks Andrew that seems to have done the trick:smileyhappy:
neilyj
cadman33619
Message 18 of 21 (205 Views)
11-02-2012 06:17 AM in reply to: neilyj
no working for me at all. guess i'll have to give up.
but i appreciate all your help guys.
Employee
peterfunkautodesk
Message 19 of 21 (200 Views)
11-02-2012 06:41 AM in reply to: cadman33619
Have you tried the linetypes that ship with Civil 3D? There are two barbed wire fences in the AeccLand.lin linetype file that contain an "X" that stay centered in the line as the line is rotated.
Peter Funk
Peter Funk
cadman33619
Message 20 of 21 (197 Views)
11-02-2012 07:15 AM in reply to: peterfunkautodesk
wow...the barbed wire line types in AeccLand.lin are perfect. had no idea they were there.
thanks so much.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
