AutoCAD Civil 3D General
neilyj
Message 11 of 21 (252 Views)
Re: Why does my linetype change if i rotate passed 180 degrees?
11-01-2012 12:45 PM in reply to: cadman33619
I can't get this to work at all...:smileyfrustrated:
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
AllenJessup
Message 12 of 21 (247 Views)
11-01-2012 12:54 PM in reply to: neilyj
If either of you want to email me a jessupa at co.rockland.ny.us I'll send both files to you.
Attached is a file created in 2012 and saved to 2007 with the linetype shown in it.
Allen
Distinguished Contributor
Message 13 of 21 (244 Views)
11-01-2012 12:59 PM in reply to: AllenJessup
i see..
ok im getting bad definition on line 2. i copied yours exactly.
AllenJessup
Message 14 of 21 (236 Views)
11-01-2012 01:15 PM in reply to: cadman33619
I've reviewed the creation of custom linetypes from the 2012 help files. The only difference I see is that they now specify the the .SHX extension. Like this:
*FENCEX,Fence with Xs
A,1.0,-0.09848,[FENCEX,FenceX.shp,s=.05],-0.09848,1.0
I also see that in the original post I said to rename the the file to a .SHP file. It should be a .SHX file.
Allen
neilyj
Message 15 of 21 (231 Views)
11-01-2012 01:56 PM in reply to: neilyj
Still no luck - I'll try again tomorrow with fresh eyes...
neilyj
Distinguished Mentor
Message 16 of 21 (220 Views)
11-01-2012 06:57 PM in reply to: neilyj
you need to compile the shp file first.
In autocad type "Compile" (without the quotes) on the commandline
Locate and select the fencex.shp file and click open.
The command line should show this
"Compiling shape/font description file
Compilation successful.  Output file D:\My Documents\Cad\AWP Cad Setup\Line Types\FenceX.shx contains 100 bytes."
Using windows explorer, copy the resulting FenceX.shx file into a folder in your support path.
Back in autocad, load the linetype from the FenceX.lin file.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
neilyj
Message 17 of 21 (198 Views)
11-02-2012 01:53 AM in reply to: andrewpuller3811
Thanks Andrew that seems to have done the trick:smileyhappy:
neilyj
Message 18 of 21 (190 Views)
11-02-2012 06:17 AM in reply to: neilyj
no working for me at all. guess i'll have to give up.
but i appreciate all your help guys.
Employee
Message 19 of 21 (185 Views)
11-02-2012 06:41 AM in reply to: cadman33619
Have you tried the linetypes that ship with Civil 3D? There are two barbed wire fences in the AeccLand.lin linetype file that contain an "X" that stay centered in the line as the line is rotated.
Peter Funk
Peter Funk
Message 20 of 21 (182 Views)
11-02-2012 07:15 AM in reply to: peterfunkautodesk
wow...the barbed wire line types in AeccLand.lin are perfect. had no idea they were there.
thanks so much.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
