Show only
Search instead for
Which subassembly works best for using a DOT Cut fill table.. (Civil 3D 2012)
I'm trying to attach a daylight subassembly that follows my DOT chart below. Is there one that does all of this or do I need to use a condtionalcutorfill and "something else" to do it? If the case, what subassembly would I use for the "something else"? If it's cut, the table below also determines the backslope... forming a ditch. How is the clear zone factored in? I need it to go the the flowline of the ditch when it's in cut. I have a design speed of 40mph, ADT of 7000+.
Highly recommend spending some time on a weekend learning the Subassembly Composer.... the tables are a bunch of simple decisions... watch the two videos at autodesk university from katie and peter... its easier to learn than it first appears ... I'm a big fan of it now.... search AU online classes for the Subassembly Composer there are only a couple of classes on it...
