Hello All:
Is it still the case with C3D 2014 that there is no curb inlet length value that gets exported to Storm Sewers using the export command. For example if I have a curb inlet part in C3D where I can vary the length of the throat opening, I set the length of the throat to 6', the export will not carry that length into Storm Sewers to be automatically populated as the inlet length in the Add/Edit Dialog box?
Previous question with a no answer:
Solved by Matt_Haokip. Go to Solution.
Hi Michael,
Unfortunately, you are correct, there is no explicit curb opening length yet in Civil 3D. You may want to consider Customized XML Part Mapping file to estabish the length. Attached is the help page screenshot for XML part mapping file further reference.
