I know this sounds like a really stupid question. Where is the subassembly composer? We have Civil3D 2013, and my understanding was that the subassembly composer was supposed to automatically install in 2013 as opposed to previous years when you had to download it from the Subscription Center.
Please help.
Thanks in advance!
Meredith
C3D 2013
64-bit
Solved by Jay_B. Go to Solution.
There's an option to install the Subassembly Composer under configure installation>subcomponents>Subassembly Composer 2013 so it may not be installed on your system if this option was not checked during installation.
I don't have it installed for 2013, but it's an external program and should be located near here.
Start Menu>All Programs>AutoDesk> AutoCad Civil 3d 2013>Subassembly Composer
This one may help:
Civil 3D 2013: Where is Storm & Sanitary Analysis & Subassembly Composer?
Mark Green
Working on Civil 3D in Canada
Im using Civil3D 2014being included in Master suite
When I install it I didnt that component below many Products
So If I want to download subassembly composer and install,
Can u teach me what should I do?
Jang Y.H from Korea
You wont see it in the ribbon of Civil3d because it's a seperately run program. There's plenty of clips on youtube that show you how to use it too.
I think the question is "How to download/install/find/run 2014 Subassembly Composer when it is not already installed?
My question is "Since it was not installed along with 'All' programs included in the 'Infrastructure Design Suite Premium 2014' deliverable then how can I get it and install it?
