Civil 3D Forum
What's going on with my Sample Lines and Section Views???
6 REPLIES 6
ravenlode
301 Views, 6 Replies
My sample lines are not gathering any data ie, in the sample line properties under (sections) the offsets and elevations have no information in them. I'm using Civil3D,2012
6 REPLIES 6
Jay_B
in reply to: ravenlode
Go to Sample Line Goup Properties "Sections" Tab, choose Sample More Sources radio button to sample data if not appearing on left under "Sections List".
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
ravenlode
in reply to: Jay_B
There is only the / existing ground / dynamic/ etc. there is no other source
Jay_B
If you have other sources available in other dwg's such as Corridor FG surface, Corridor Datum surface etc. Data reference them into this dwg using Data Shortcuts. Attach the corridor as an Xref
Then Sample those sources.
Hope this helps.
C3D 2018.1
C3D 2016 SP4
ravenlode
in reply to: Jay_B
there is no other data source. i can create profiles it's just the sample lines are not  working
mathewkol
Attach the drawing. Takes too long to guess what your problem could be.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
ravenlode
in reply to: mathewkol
I opened a new drawing and w-blocked everything but the alignments into it. Now it works fine. Something must of gotten corrupted when I had a "fatal error" when I tried to do a line by extension.
Rail Community
