Civil 3D Forum
What is your favorite AutoCAD error?
29 REPLIES 29
Message 1 of 30
publicworksengineer
1669 Views, 29 Replies
From AutoCAD Civil 3D 2009, it's and oldie but a classic nonetheless.
29 REPLIES 29
Message 2 of 30
How's this?
Message 3 of 30
I see your DOCPROP and I raise you a MTEXT
AutoCAD Civil 3D 2012
Message 4 of 30
Funny you should ask?
There is no dialog box - acad simply locks up if I try to use the calculator in the properties dialog box.
Joe Bouza
Message 5 of 30
I don't recall what I was doing, but Civil 3D returned this error:
It gets funnier!  I clicked "Yes", and then got this error:
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Message 6 of 30
Rick Jackson
Survey CAD Technician VI
Message 7 of 30
KirkNoonan
in reply to: Joe-Bouza
@Joe,
I had that one too. It turned out that the calculator box had moved off the screen. Try the ALT+SAPCE then M then arrow trick to get it back.
Kirk
Message 8 of 30
in reply to: publicworksengineer
my daily favorite is when autocad just dissapears from my screen with no warning or error box...
Message 9 of 30
We used to call it the QED. Quick Exit to DOS. Program disappeared and left you at a DOS prompt. Now I supposed its a QEW(indows).
I do have a more recent one. I tried to install 2012 from a network deployment. I got an error during the install but hit continue. When I try to run I get an error that it fails a "Side by Side comparison". But it doesn't tell what it's comparing. The program wouldn't run and I couldn't Uninstall it. I removed it manually following the Clean Install procedure. But it fails.
Allen
Allen Jessup
CAD Manager - Designer
Message 10 of 30
Joe-Bouza
in reply to: KirkNoonan
@Kirk
Thanks a ton. I was getting silly frustrated over that.
Joe Bouza
Message 11 of 30
@jeff, you sir are an epic error generator, well done.
Message 12 of 30
I sometimes wonder what would have happened if I had clicked 'No"...
Jeffrey Rivers
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Message 13 of 30
Helpful...   Hmm  Ok or X
Message 14 of 30
C. Austin, I have been getting that same error for a few weeks now.  It only occurs when I shut down Civil3d at the end of the day.
Message 15 of 30
I have only gotten it twice ever and both times it was during startup as you can see by the background.  No idea why.
Message 16 of 30
I always enjoy this one after attempting a qsave:
Message 17 of 30
Is this by chance when using autoturn?
We have gotten that after we place an autoturn into a drawing and found out if you explode it down to lines and arcs, you can save it again.
Message 18 of 30
A good guess I forgot about that, but no. I was just hatching some polylines to get some areas. We decided not to upgrade AutoTurn when we went to 2011. BTW There is a very workable alternative that doesn't cost anything here: www.glamsen.se/CadTools.htm
Message 19 of 30
Sinc
How about this one, which I seem to get a lot in C3D 2012 SP1:
Sinc
Message 20 of 30
When posting to a discussion group regarding errors I get this fitting reply...
Rail Community
