Civil 3D Forum
What is the best way to create a design surface?
4 REPLIES 4
rvandever21
1092 Views, 4 Replies
I need help creating a design surface from an original surface. The current method I am using is taking alignments and adjusting the elevations on the profile. I would add the alignment as a breakline to create the design surface. Is there a simple way to create a design surface?
4 REPLIES 4
AllenJessup
in reply to: rvandever21
Look at help and tutorials on Corridors and Corridor Surfaces.
Allen Jessup
CAD Manager - Designer
Or you can use Feature Lines.
Todd Rogers
After I change the elevation of the profile, I change the alignment to a feature line.  Then I add the line as a breakline to the surface.
Joe-Bouza
Design surface is quite a broad term. All the other suggestions apply.
But could you elaborate on what constitutes your design surface? Parking lot , roadway, subdivision, mining, basins, landfills? There is just so many ways to skin this.
Your Name
Rail Community
