AutoCAD Civil 3D General
Employee
Message 1 of 16 (585 Views)
What do you use for Water Network Analysis and other Pressure Pipe Analysis
585 Views, 15 Replies
01-20-2009 09:19 AM
Hi Folks
I am doing some research on pressure pipe analysis workflows.
What are you using for potable water network analysis? Forcemain analysis? Other pressure transmission lines (gas, etc)?
Last time I did system and fire flow for water networks, my company had some custom spreadsheets and excell add ons that were tabular and had to have manual entry.
What might other people be working with?
Dana Probert
Dana Probert, P.E.
Technical Marketing Manager, Civil Engineering
Blog: BIM on the Rocks
Learn More About BIM for Infrastructure
*Joe Bouza
Message 2 of 16 (585 Views)
Re: What do you use for Water Network Analysis and other Pressure Pipe Analysis
01-20-2009 09:30 AM in reply to: dana.probert
Haven't for some time, but I used to use Haestad
methods water cad. Very intuitive & user friendly.
Thanks, Joe
Joseph D. Bouza, P.E.
Civil 3D 2008
LDT 2008
Win XP pro
v 2002,
sp 2
hp workstation xw4600
Intel Core Duo CPU
E7200 @2.53 GHz
3 GB
RAM
NIVDIA Quadro FX 1700 (512MB)
The mantra of a former Flamer:
If you are forced to eat an Elephant, don’t complain about it; Take one
bite at a time.
In
memory of the King of Work-arounds
"The only Constant is Change".
"The only thing worse than training your staff, and having them leave is
not training your staff, and having them stay." :-o
A reminder taken
from Graphics Solution Providers' Calendar
page
Hi Folks
analysis workflows.
etc)?
working with?
Dana
Probert
Employee
Message 3 of 16 (585 Views)
01-20-2009 09:35 AM in reply to: dana.probert
Questions for WaterCAD (and other) users:
Tell me about how you get your data into it? What inputs does it take?
What outputs do you use?
Do you make exhibits and reports that need to be turned into agencies? Is there any information that you take back into your Civil 3D/LDT/Autocad environment?
Dana Probert, P.E.
*David Dixon
Message 4 of 16 (585 Views)
01-20-2009 09:52 AM in reply to: dana.probert
We use Bentley Watercad XM. We typically use import a .dxf file from
AutoCAD, then input the "intelligent" linework and data in the Watercad
user interface.
I'm not an expert in Watercad by a long stretch; we have other utility
engineers who use it a lot more. I believe there are typical reports
preinstalled in Watercad that our Federal Gov't clients like to see.
As for importing back into Civil 3D etc, we do not currently do this
since Civil 3D does not have pressure pipe design / drafting
capability. The exhibits that can be printed to a color printer
(11"x17") from Watercad is usually sufficient to include in our reports.
Having said this and from a strictly plan production stand-point, I
would like to be able to have Civil 3D help me draft in water lines in
profile, including vertical bends and fittings. I know there are ways
to accomplish this through creative use of the current Pipes module, but
I would like to see an area specifically dedicated for pressure piping.
Sounds like that's what you may be investigating.
Dave
David Dixon
Clark Nexsen, Architecture & Engineering
Civil 3D 2009 / Raster Design 2009
Dell Precision T3400, XP Pro SP2, 4GB
NVidia Quadro FX 750 Dual Display
http://dca2civil3d.blogspot.com
*Joe Bouza
Message 5 of 16 (585 Views)
01-20-2009 11:06 AM in reply to: dana.probert
Watercad as I recall had the ability to extract
elevation data from a LDT file but it was clunky. However, setting defaults for
fittings, various headlosses was pretty straight forward. It was NOT dat entry
Free
Thanks, Joe
Civil 3D 2008
LDT 2008
Win XP pro
v 2002,
sp 2
Intel Core Duo CPU
E7200 @2.53 GHz
3 GB
RAM
bite at a time.
In
A reminder taken
page
Questions
What outputs do you
use?
*fcobob
Message 6 of 16 (585 Views)
I typically use WaterCAD XM version by Bentley integrated with AutoCAD.
That way I can convert my autocad entities into pipes. There is a tool
within WaterCAD to extract node elevations from a TIN surface (not working
very well for me lately though). Proposed pipe diameters need to be input
in a table form (when multiple editing) or property dialog box for
individual edits. exhibtis then are prepared color coding pipes by
diameters, pressure zones, etc.and obiously the output data we are
concerened above pressure velocities, headlosses, available fire flow, etc.
I typically use it for water distribution and tranmission systems. For
force main analysis I typically combine it with my gravity system in
SewerCAd by Bentley.
"David Dixon" wrote in message
news:6108315@discussion.autodesk.com...
user interface.
Dave
David Dixon
*David Dixon
Message 7 of 16 (585 Views)
01-20-2009 12:00 PM in reply to: dana.probert
yes, that's great. our version is the standalone version of Watercad.
We do not own the version that works within ACAD.
> user interface.
> Dave
> David Dixon
*Expert Elite*
Civil3DReminders.com
Message 8 of 16 (585 Views)
01-20-2009 12:32 PM in reply to: dana.probert
Create 3DPolylines of the pipe network. Drape them on the surface, then lower 3' or what ever distance is required. Export to SHP file and import the SHP file into WaterCAD.
Christopher
http://blog.civil3dreminders.com/
http://style.civil3dreminders.com/
Civil Reminders
http://www.CivilReminders.com/
Distinguished Contributor
Message 9 of 16 (585 Views)
01-20-2009 06:27 PM in reply to: dana.probert
We use WaterCAD and DXF to import.
Mark Spatz, P.E.
Herbert, Rowland & Grubic, Inc.
Harrisburg, PA
Valued Mentor
Message 10 of 16 (585 Views)
01-20-2009 11:46 PM in reply to: dana.probert
We use mike urban
http://www.dhigroup.com/Software/Urban/MIKEURBAN/Details/WaterDistribution.aspx
which takes dxf and shp or text file input.
Regards
Justin
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
