Civil 3D Forum
What do you use for Water Network Analysis and other Pressure Pipe Analysis
15 REPLIES 15
Message 1 of 16
dana.probert
2544 Views, 15 Replies
Hi Folks
I am doing some research on pressure pipe analysis workflows.
What are you using for potable water network analysis? Forcemain analysis? Other pressure transmission lines (gas, etc)?
Last time I did system and fire flow for water networks, my company had some custom spreadsheets and excell add ons that were tabular and had to have manual entry.
What might other people be working with?
Dana Probert
Dana Probert, P.E.
Technical Marketing Manager, Civil Engineering
Blog: BIM on the Rocks
Learn More About BIM for Infrastructure
15 REPLIES 15
Message 2 of 16
in reply to: dana.probert
Haven't for some time, but I used to use Haestad
methods water cad. Very intuitive & user friendly.
Thanks, Joe
Joseph D. Bouza, P.E.
Civil 3D 2008
LDT 2008
Win XP pro
v 2002,
sp 2
hp workstation xw4600
Intel Core Duo CPU
E7200 @2.53 GHz
3 GB
RAM
NIVDIA Quadro FX 1700 (512MB)
The mantra of a former Flamer:
If you are forced to eat an Elephant, don’t complain about it; Take one
bite at a time.
In
memory of the King of Work-arounds
"The only Constant is Change".
"The only thing worse than training your staff, and having them leave is
not training your staff, and having them stay." 😮
A reminder taken
from Graphics Solution Providers' Calendar
page
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hi Folks
analysis workflows.
etc)?
working with?
Dana
Probert
Message 3 of 16
dana.probert
Questions for WaterCAD (and other) users:
Tell me about how you get your data into it? What inputs does it take?
What outputs do you use?
Do you make exhibits and reports that need to be turned into agencies? Is there any information that you take back into your Civil 3D/LDT/Autocad environment?
Dana Probert, P.E.
Message 4 of 16
We use Bentley Watercad XM. We typically use import a .dxf file from
AutoCAD, then input the "intelligent" linework and data in the Watercad
user interface.
I'm not an expert in Watercad by a long stretch; we have other utility
engineers who use it a lot more. I believe there are typical reports
preinstalled in Watercad that our Federal Gov't clients like to see.
As for importing back into Civil 3D etc, we do not currently do this
since Civil 3D does not have pressure pipe design / drafting
capability. The exhibits that can be printed to a color printer
(11"x17") from Watercad is usually sufficient to include in our reports.
Having said this and from a strictly plan production stand-point, I
would like to be able to have Civil 3D help me draft in water lines in
profile, including vertical bends and fittings. I know there are ways
to accomplish this through creative use of the current Pipes module, but
I would like to see an area specifically dedicated for pressure piping.
Sounds like that's what you may be investigating.
Dave
David Dixon
Clark Nexsen, Architecture & Engineering
Civil 3D 2009 / Raster Design 2009
Dell Precision T3400, XP Pro SP2, 4GB
NVidia Quadro FX 750 Dual Display
http://dca2civil3d.blogspot.com
Message 5 of 16
Watercad as I recall had the ability to extract
elevation data from a LDT file but it was clunky. However, setting defaults for
fittings, various headlosses was pretty straight forward. It was NOT dat entry
Free
Thanks, Joe
Civil 3D 2008
LDT 2008
Win XP pro
v 2002,
sp 2
Intel Core Duo CPU
E7200 @2.53 GHz
3 GB
RAM
bite at a time.
In
A reminder taken
page
Questions
What outputs do you
use?
Message 6 of 16
I typically use WaterCAD XM version by Bentley integrated with AutoCAD.
That way I can convert my autocad entities into pipes. There is a tool
within WaterCAD to extract node elevations from a TIN surface (not working
very well for me lately though). Proposed pipe diameters need to be input
in a table form (when multiple editing) or property dialog box for
individual edits. exhibtis then are prepared color coding pipes by
diameters, pressure zones, etc.and obiously the output data we are
concerened above pressure velocities, headlosses, available fire flow, etc.
I typically use it for water distribution and tranmission systems. For
force main analysis I typically combine it with my gravity system in
SewerCAd by Bentley.
"David Dixon" wrote in message
news:6108315@discussion.autodesk.com...
user interface.
Dave
David Dixon
Message 7 of 16
yes, that's great. our version is the standalone version of Watercad.
We do not own the version that works within ACAD.
> user interface.
> Dave
> David Dixon
Message 8 of 16
Create 3DPolylines of the pipe network. Drape them on the surface, then lower 3' or what ever distance is required. Export to SHP file and import the SHP file into WaterCAD.
Christopher
http://blog.civil3dreminders.com/
http://style.civil3dreminders.com/
Civil Reminders
http://www.CivilReminders.com/
Message 9 of 16
mspatz
We use WaterCAD and DXF to import.
Mark Spatz, P.E.
Herbert, Rowland & Grubic, Inc.
Harrisburg, PA
Message 10 of 16
ralstogj
We use mike urban
http://www.dhigroup.com/Software/Urban/MIKEURBAN/Details/WaterDistribution.aspx
which takes dxf and shp or text file input.
Regards
Justin
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
Message 11 of 16
You're just full of amazing stuff, man.  What
the H?  You're not really one person are you?  Legion.
SHP file into
WaterCAD.
Christopher
Message 12 of 16
Actually I did that method once, didn't do a post and then forgot how I got the elevation to come in for the node. The method still brings in the linework and makes nodes and pipes and someday when I have to do a subdivision again I'll figure out how to get the elevation to come in with the node and do a post about it. It's still faster than importing a DXF and then tracing over it. Although we are using an older version of WaterCAD and there may have been some improvements to pull information from the DXF.
I'm one person who hates to do things manually when the computer can automate the tasks.
Christopher
Civil Reminders
Message 13 of 16
Chris - you're not the only one who hates doing things manually when the
computer or program should automate the tasks!
Matthew Anderson, PE
> automate the tasks.
> Christopher
> http://blog.civil3dreminders..com/
Message 14 of 16
nkg2
Dana -
Can you tell us whether or not Civil 3D will incorporate a haydraulic analysis tool and if so do you have a time frame? I am about to spend some money on WaterCAD and SewerCAD and before I drop some coin, I would really like to know what you know. It would be swell if you guys did but if not I understand too.
On a side note, WaterGEMS from Bentley supports AutoCAD but not Civil3D, is it because of how new Civil3D is and AutoDesk does not share sensitive program language or is Bentley trying to pull away from AutoDesk?
Thank you in advance!
***Viewer/Reader Discretion is Advised***
Autodesk 2022- Architectural, Engineering and Construction Subscription & Infraworks
Windows 10 Professional, x64, Microsoft Surface Pro 3
Message 15 of 16
drazen-ars
We made application Hydra on top of Civil 3D/AutoCAD which can automatically and intuitively generate all necessary data for Epanet. Solution is widely used in Eastern and Central Europe. Can communicate through LandXML format.
Best regards,
Drazen Galic
StudioARS Croatia
www.studioars.com
d dot galic at
Message 16 of 16
Force mains, we typically use an Excel spreadsheet setup for Hazen Williams. Get your equivalent lengths in each size, plug it in and you are done.
For drinking water distribution, we will typically use EPANet.
Rail Community
