Wblock won't work. Even if I shut down my computer, restart a new drawing and draw a simple polygon, it won't let me wblock it. I can select the objects but it won't let me select a file location. It is just blank. My filedia is set to <1> but nothing will happen when I select the file location. If I select the default location nothing happens, the program just hangs in suspension and does nothing. I have to shut down Civil 3D from the task manager and restart?
Please see attached.
Solved by StumpMasterFlex. Go to Solution.
It was being caused by my phone. I had my Motorola phone plugged into the computer to charge. When I unplugged the phone everything worked fine, when I plugged the phone back in Wblock would not work.
Wow. Who woulda thunk it?
Thanks for following up. You just saved a bunch of us some head-scratching.
Tim
