I am getting this warning as I try to save my drawing. Not sure what it means.
My drawing file crashed (FATAL ERROR) before I was able to complete the save. I did a MAPCLEAN followed by AUDIT, but still get the error message when trying to save.
I am using C3D 2011 with Windows 7.
Any ideas would be greatly appreciated.
Solved by Sinc. Go to Solution.
This usually fixes it
Enter in the command line: (entdel(handet"206CF"))
Repeat this for any other handles that crop up,
Nathan
Hi ignich-
Just as Nathan had suggested, that command will remove the object. For a bit more information about this error, please have a look at this blog post: http://beingcivil.typepad.com/my_weblog/2010/08/warning-multiply-owned-objects.html
Hope this helps!
how did you find out the error #'s
I'm having the same issue after doing the initial Command:
(entdel(handet"22f29"))
; error: no function definition: HANDET
sounds like i need the error # to fix the problem.
Raising the Dead:
OK, the fix listed, now does not seem to work for C3D 2013. AutoCAD just replies "nil"
Anyone have another solution to this?
@msarqui wrote:
Autodesk!!!! Are you there??
Not necessarily, no. This is a peer to peer help forum for the most part. Yes, we do sometimes get a few of the Autodesk people to come through here. But if you want real help from them you must submit a support request through your subscription center or the product feedback page.
Can you post your drawing to see if someone here can help?
I'm having the same problem. After I delete the entity though and run audit, the drawing crashes.
Since the previous poster didn't do as requested and post the actual dwg file, I'll do so here.
Command: _QSAVE
*Warning* Multiply owned object, handle "A4A7"
*Warning* Multiply owned object, handle "A4A6"
*Warning* Multiply owned object, handle "A4A5"
Command:
Command:
Command: (entdel (handent "5154"))
; error: bad argument type: lentityp nil
Command: (entdel (handent "5153"))
EDIT: I forgot to ask this but instead of JUST DELETING the offending object(s), is there a way to repair them or at least explode them to 3d polylines (assuming they're featurelines) so that I can recreate them? At a very minimum, I'd need to know which objects they are.
Don Ireland
Engineering Design Technician
@Jeff_M wrote:
Don, I am not seeing that error message in your file, using C3D 2016. Also, your (entdel...) lines don't look right. You have to input the actual handle that says it's multiply owned:
(entdel (handent "A4A7")) would be correct based on the outpout you show.
That's odd. I'm also using C3D 2016 here (SP1). I've seen this error previously in 2012 & 2014 too.
I copy/pasted the lisp code from the "answer" posted above. I guess it never dawned on me that I needed to change it to the actual handle(s).
Any thoughts on the second part of the question (the "EDIT")?
Don Ireland
