Civil 3D Forum
WMS Luftbild auf DGM Projezieren
1 REPLY 1
FriedhelmBock1862
309 Views, 1 Reply
Hallo,
ich habe ein Luftbild über WMS geladen. Über Höhenpunkte habe ich ebenso ein Digitales Geländemodel erzeugt. Gibt es eine Möglichkeit die WMS Luftbilder auf das DGM zu Projezieren.
Mit einfachen Rasterbildern ist diese ja möglich.
Autocad Civil 2014
1 REPLY 1
projection of an image onto a surface is only possible with images that are available as image-files (fixed raster content) and not as live connections (as live connections like WMS services are regenerated everytime you do a zoom or regen, so this continuously changes it's content).
If you are allowed for this datasource you can do the following steps:
a) create (within a new drawing) a layout with one viewport
b) add your WMS connection
c) within the viewport zoom to the area you need as raster
d) plot that layout (using option "extents", so only the viewport-size get's exported) to a raster format file
e) open your drawing with the surface
f) use command _IMAGE to reference the file you previously created, the coordinates are then used from the borders of the viewport in your drawing used above (a-d).
But again, read the licensing rules for that WMS-service, because downloading the data and reusing it might conflict with those rules!
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Rail Community
