I am using C3D 13 and have created a surface using points that were shot on a 50' grid.
Now I am looking for the easy button to get a volume.
You need a second surface to get a volume. Create the surface by using just the points that form the base of the borrow area to create a datum surface. Then, bring up the volumes dashboard and make a volume surface based on the datum surface as your base and the complete surface as your comparision.
What exactly is your surface showing - the pit after it has been completed? Is a 50' grid sufficient to define the pit correctly e.g. breaklines for top and bottom of slopes etc??
You will need an original ground topo as well in that case
neilyj (No connection with Autodesk other than using the products in the real world)
