Civil 3D Forum
Volume of a borrow pit
3 REPLIES 3
goliver
930 Views, 3 Replies
I am using C3D 13 and have created a surface using points that were shot on a 50' grid.
Now I am looking for the easy button to get a volume.
3 REPLIES 3
ccoles
in reply to: goliver
You need a second surface to get a volume. Create the surface by using just the points that form the base of the borrow area to create a datum surface. Then, bring up the volumes dashboard and make a volume surface based on the datum surface as your base and the complete surface as your comparision.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
neilyj666
What exactly is your surface showing - the pit after it has been completed? Is a 50' grid sufficient to define the pit correctly e.g. breaklines for top and bottom of slopes etc??
You will need an original ground topo as well in that case
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
neilyj666
in reply to: ccoles
If you just use the base of borrow area as a comparison this will only report the vertical volume above the base and not reflect the true volume as the batter slopes are excluded - this may be acceptable for royalty payments etc; it really depends on how the borrow pit measurement specification is worded.
Rail Community
