AutoCAD Civil 3D General
Distinguished Contributor
RafaelMoreno
Message 1 of 7 (706 Views)
Volume calculation for 3D Faces object
706 Views, 6 Replies
01-09-2013 11:00 AM
Hi:
I have a volume in my CAD file described by 3D Faces. Is there anyway to know what is the volume of this volume -that represents an open pit-?
Every time that I do a volume I do by the comparison of 2 surfaces but this is not the case now.
Thanks in advance
Rafael
*Pro
dgordon
Message 2 of 7 (703 Views)
Re: Volume calculation for 3D Faces object
01-09-2013 11:14 AM in reply to: RafaelMoreno
in order to get the volume of a pond for instance if it is filled to elevation 979.00
a flat surface using a rectangle with elevation 979 which is larger than the pond is used to compare to the pond surface.
does this make sense?
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
troma
Message 3 of 7 (697 Views)
01-09-2013 11:24 AM in reply to: RafaelMoreno
Do the 3D faces represent the pit, or the volume of the pit?  The way you wrote it makes me think the latter.  Where did they come from?  It is possible that a Volume surface was exploded or had the 3D faces extracted from it.  If that is the case, you need to build a surface from the 3D faces and another surface at elevation zero, and compare the two.
Credit where credit is due! Give kudos or accept as solution whenever you can.
RafaelMoreno
Message 4 of 7 (684 Views)
01-09-2013 01:36 PM in reply to: troma
Hi Troma, thanks for your long replay:
The 3D faces that I have represent the Pit. So trying to to clean the file in order to get the 3D faces that represent the surface of the pit is almost....impossible.
There is not way tof calculating the volume taking the 3D faces in the way I am describing?
Rafael
mathewk
Message 5 of 7 (673 Views)
01-09-2013 07:54 PM in reply to: RafaelMoreno
Civil 3D only calculates volumes using surfaces. You'll need to create surfaces and then calculate volumes. I doubt AutoCAD itself can do any such volume calculation.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
troma
Message 6 of 7 (663 Views)
01-10-2013 05:27 AM in reply to: RafaelMoreno
What do you mean about 'Cleaning' the file?
If you have 3D faces that represent the pit, you can use them to build a TIN surface that duplicates them exactly.
Then you need to create another surface at the top of the pit.  That will either be flat, as described earlier by others, or you could match it to the top of slope of the pit.
You can then calculate a volume between the two surfaces.
RafaelMoreno
Message 7 of 7 (637 Views)
01-11-2013 11:38 AM in reply to: troma
Hi:
Thanks for the solution. I was lucky that the file came not only with the Volume that descrbed the pit but also with the Surface that described the same pit in a different layer, then I build the surface so I can now calculate the volume comparing this surface with the Original Ground surface
Regards
Rafael
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
