Hi people, i have little problem with calculating cut/fill volumes. I know how to calculate volumes between 2 surfaces (existing ground surface and datum surface) but i want to add to fill volume some more volume which will be for humus (surface layer wich cannot be used for fill base). In the same way i dont want to add it to cut volumes because it will be excavated. For calculating cut/fill volumes i use earthworks material list (or cut and fill lists) in sample line views. I am using custom daylight subassembly made with subassembly composer. Ah almost forgot, i use C3D 2014.
I uploded 2 files wich will help me to explaing what exactly i want to do with volumes this 30sm are those additional volumes wich i want to add to my Fill volume. Thank you in advance !!
