How is layout viewport transparency controlled? The illustration under the Help topic "About Layout Viewports" shows two overlapping viewports that are mutually transparent. That's exactly what I want. BUT, in my system, overlapping layout viewports are mutually opaque by default and I cannot figure out how to change that, AND all the discussions I am able to Google up are complaints that overlapping layout viewports are transparent and everyone is trying to figure out how to make them opaque, with WIPEOUTs or whatever ... very frustrating!
How do I get transparent overlapping layout viewports? I am using Civil 3D 2014.
Many thanks for any help you can provide.
Solved by rkmcswain. Go to Solution.
Solved by neilyj666. Go to Solution.
This solution doesn't work anymore. (AutoCAD 2019)
Created a new visual style,
turned background off,
applied to all viewports,
but when I plot DWG to PDF the background is still there.
Same issue as Marco. Backgrounds is off, but VP backgrounds are still displaying opaque.
I had the same issue with paper space txt and dimensions being behind an opaque view port. It was fine last week but this week the viewport changed and nothing i did fixed it. So i just created a new viewport and that worked. Very annoying problem.
Someone have solved this incredible bug????
Also autocad 2020-2021-2022-2023 have the some problem unresolved....
This is crazy !!!!!!!!
Please solve this!!!!!!
