I have a road design with a corridor. I want to plot the plan and profile but not show the sub-assembly section that are every 25 feet. I can't freeze the layer because then I only see my baseline for the alignment. I want to see the offsets of the road. I have tried creating an offset of my alignment but it will not create the offsets for some reason.
What would be the best way to attack this trouble. I want my final output to show the entire road over my OG topo survey but do not want to see section lines every 25ft
You have to edit the code set for the assembly
Joe Bouza
