Civil 3D Forum
Very Ugly eTransmit Errors
5 REPLIES 5
Louisa
712 Views, 5 Replies
When performing and eTransmit in C3D08 I am getting some errors that make me nervous. This project does contain XREFS and Data shortcuts.
The command line informs me that it is skipping the Xrefs and then saying "Error: Erase Failed (eContainerNotEmpty)" or Erase Failed (eNotApplicable)" (see attached pdf to see errors "in person")
At the end of it all, I still get a zip file containing the main dwg - but none of the xref's.
Can anyone tell me whats up here?
5 REPLIES 5
in reply to: Louisa
Run a recovery on the xref that gives the error messages?
wrote in message
news:5689219@discussion.autodesk.com...
none of the xref's.
ceethreedee.com
mmmm... same error Civil 3d 2013
erase failed (eNotApplicable)
when etransmitting. They are old drawings from 2008
investigating now.
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
lstarbird
in reply to: Louisa
I saw this today while eTransmitting:
ERROR: erase failed (eNotApplicable)
Just curious if anyone figured out what was going on?
tcorey
in reply to: lstarbird
There is a known issue on ExporttoAutoCAD that causes a similar error. The solution is to be sure all surfaces are unlocked before you run the command. Maybe that will help you. Maybe.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
granat1
in reply to: Louisa
I receive also this messages
I jump out the window
I am in the hospital
Now I fell better …..
Rail Community
