Hi -
I'm trying to insert a google earth image and earth around some survey
data. The image comes in just fine, just where it's supposed to.
However, the surface that comes in seems to be incorrectly scaled along
the vertical. In other words, the elevations seem to be affected by some
kind of "flattening" value, what you would expect in a profile if the
vertical exaggeration was set less than 1.0. The whole area is quite a
bit lower than the survey indicates, and it's much "flatter" - the hills
aren't as high, and the low spots aren't as low relative to the
surrounding terrain. Make any sense? The horizontal layout of
identifiable spots: creeks, ponds, hills, etc, appear to be in the
correct position. Any ideas? I'm using Civil 3D 2010, sp2, and Google
Earth 5.0.11337.1968 (beta).
Thanks in advance.
Big Dave
