I added a free vertical curve and don't see the vertical curve information. Can someone help?
When you say "don't see the vertical curve information".
Where are you looking for it?
Do you mean it's not labeled or you can't see the infomation in the "Profile Geometry Editor"?
And Specifically where can't you see the information?
Not a lot of information to go on but try this.
Select the profile_Rt click_Edit Labels_
Does it show a "profile label set" that includes both sag and crest curve labels?
If above is yes then is there a weeding factor being applied? (you'll have to scroll to right to see weeding)
If weeding factors exist for the curve labels delete these values and Apply.
cammand_Regenall.
Have you looked at the Profile Grid View to ensure the cuve is being added?
Are you talking about the curve not being labeled or you cannot see the vertical curve itself?
Bill
