Thanks for pointing that out, Chakri. It seems from the thread that it may
have found its way into a rather "out of the way" location, since the
original poster and most of the subsequent comments sound as if they don't
know where to find it.
A picture is worth...
Would you mind doing a screen capture, and posting the place to set the
True/False statement.
Don Reichle
"King Of Work-Arounds"
Barghausen Consulting Engineers
Kent, WA USA
LDT3 - SP1/CD3 - SP1
On WIN2K SP4
Dell 1.6 Ghz P4
512MB RAM
NVIDIA 32MB AGP
"Chakri Gavini" wrote in message
news:41b6fb8b_2@newsprd01...
> Matt, Landman and Don
> Thanks for your contribution on this subject and the requirement is noted.
> This spun off a meaningful discussion among some of us.
> Don - About vertical geometry points as assembly insertion locations (and
> therefore sample lines creation) is already in Civil 3D 2005).
> Thanks for your input again.
> Chakri
> Autodesk
> "Don Reichle" wrote in message
> news:41b680c7$1_3@newsprd01...
> > Hey Matt;
> > I have to ask if they ever added this function to LDT?
> > Mr. Simeone, I would place this function high on the wish list, as
> probably
> > easy to handle to boot (at least for the "extreme" geometry points -
> > High/Low points). Since you have the vertical geometry being dynamically
> > updated, it should be fairly easy to acquire the Crest and Sag stations
> "on
> > the fly".
> > The hard part is getting all of us to agree to only place PVIs at whole
> unit
> > stations at a minimum. I know that asking for PVIs at only 25 unit
> intervals
> > is asking way too much. Then we have to decide on whether to allow
> Relative
> > or Actual stationing intervals. I guess it would depend on whether we
like
> > to stay on good terms with our survey crews or don't care how long it
> takes
> > them to write those odd stations down on the lath.
> > Maybe this isn't as easy as it first seemed, huh? "Variables" sounds
like
> a
> > pretty apt name to me.
> > Don Reichle
> > Kent, WA USA
> > On WIN2K SP4
> > Dell 1.6 Ghz P4
> > 512MB RAM
> > NVIDIA 32MB AGP
> > "Matt Kolberg" wrote in message
> > news:41b4a095$1_2@newsprd01...
> > > Thanks, everyone. I guess I'll have to do it that way until Autodesk
> adds
> > > this as an automatic feature.
> > > "Landman" wrote in message
> > > news:41afa0c0$1_3@newsprd01...
> > > > Matt here is a fast way to add vertical geo points into your sample
> > list.
> > > > Under frequency to apply to assemblies box pick on the plus
> > > > move your cursor to the location on your profile
> > > > when stationary the box will tell you the station relative the
> > > > horizontal but below it will tell you the station relative the
> vertical
> > > > just enter the station and repeat for each critical location on the
> > > > vertical.
> > > > Hope this helps
> > > > news:41af4cf7$1_2@newsprd01...
> > > > > Too early in the morning. Can it be done automatically...... No. I
> > dont
> > > > > believe so. The only ones that are done automatically are those
> found
> > in
> > > > the
> > > > > Edit Command Settings - Creat Corridor dialog box. Profile
Geometry
> > > Points
> > > > > True.
> > > > > news:41af4c51$1_3@newsprd01...
> > > > > > Matt.
> > > > > > You could try to insert a region at a specific station under
your
> > > create
> > > > > > corridor dialog box. Just right click on your baseline sample
and
> > > insert
> > > > a
> > > > > > new region using the same assembly. Make the start and end
> stations
> > > the
> > > > > > same. You will have to enter a new region for each specific
> station
> > on
> > > > the
> > > > > > vertical curve. I have not tried it yet. Let me know if this
> works.
> > > > > > Robert Howell
> > > > > > news:41af44f2$1_1@newsprd01...
> > > > > > > I see that I can add additional sample points within
horizontal
> > > > curves,
> > > > > > > spirals etc in a corridor. I can't seem to find where I can
> > sample
> > > > > > > additional stations within vertical curves. Can this be done
> > > > > > automatically,
> > > > > > > or would I have to specify stations manually? Add this to a
> wish
> > > list
> > > > > if
> > > > > > it
> > > > > > > can't be done.
> > > > > > > Matt Kolberg
