ShawnMcCorkle1211
Message 1 of 6 (1,002 Views)
Vertical Curve "r" Value
1002 Views, 5 Replies
06-21-2013 10:05 AM
I need to add the "r" value to the vertical curve labels in the profile (|G2-G1| / L).
Is there a way to add this property to the text component editor?  I see a lot of different components listed, but no "r" value.
neilyj
Message 2 of 6 (997 Views)
Re: Vertical Curve "r" Value
06-21-2013 10:31 AM in reply to: ShawnMcCorkle1211
k value?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Valued Mentor
ccoles
Message 3 of 6 (988 Views)
06-21-2013 10:54 AM in reply to: neilyj
The 'r' value (rate of change of curve) is inverse to the K value. r=1/K.
You will probably need to make an expression to show this value.
Windows 7 64-bit
HP Z600 8 Gig RAM
Civil 3D 2013
ShawnMcCorkle1211
Message 4 of 6 (981 Views)
06-21-2013 11:09 AM in reply to: ccoles
I thought that I could manipulate it that way, but wasn't sure how to add an expression.
Can someone walk me through how to add the expression to the components?
sboon
Message 5 of 6 (956 Views)
06-21-2013 07:17 PM in reply to: ShawnMcCorkle1211
The expression you build will become part of a label.  Start by expanding the Settings group for the type of label that you intend to use the expression with - profile curves in this case.  Right click on the Expressions option, and start a new one.
Once you have an expression built it will available in the dropdown list that you can insert into a label style, just like the built in parameters.
ShawnMcCorkle1211
Message 6 of 6 (938 Views)
06-22-2013 05:27 AM in reply to: sboon
Thanks for the help.  That worked perfectly.
For some reason the Expression Option was not present. After repeated closing and restarting C3D, it finally appeared.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
