Civil 3D Forum
Vertical Curve "r" Value
5 REPLIES 5
ShawnMcCorkle1211
2220 Views, 5 Replies
I need to add the "r" value to the vertical curve labels in the profile (|G2-G1| / L).
Is there a way to add this property to the text component editor?  I see a lot of different components listed, but no "r" value.
5 REPLIES 5
k value?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
ccoles
in reply to: neilyj666
The 'r' value (rate of change of curve) is inverse to the K value. r=1/K.
You will probably need to make an expression to show this value.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
ShawnMcCorkle1211
in reply to: ccoles
I thought that I could manipulate it that way, but wasn't sure how to add an expression.
Can someone walk me through how to add the expression to the components?
sboon
in reply to: ShawnMcCorkle1211
The expression you build will become part of a label.  Start by expanding the Settings group for the type of label that you intend to use the expression with - profile curves in this case.  Right click on the Expressions option, and start a new one.
Once you have an expression built it will available in the dropdown list that you can insert into a label style, just like the built in parameters.
Steve
Expert Elite Alumnus
ShawnMcCorkle1211
in reply to: sboon
Thanks for the help.  That worked perfectly.
For some reason the Expression Option was not present. After repeated closing and restarting C3D, it finally appeared.
Rail Community
