AutoCAD Civil 3D General
Active Member
Message 1 of 3 (466 Views)
Vertical Curve Labels on Profile
466 Views, 2 Replies
01-11-2013 03:38 PM
I just created a profile by choosing my PVIs and linking them together with tangent curves.  How do I add labels to show the vertical curve properties (K value, curve length, station of PVI, elevation of PVI...)?  I'm guessing I have to edit the label style?  Any help is appreciated!
Thanks.
Active Contributor
Message 2 of 3 (458 Views)
Re: Vertical Curve Labels on Profile
01-11-2013 04:47 PM in reply to: accarr03
  1. Select your alignment
  2. Add labels
  3. Type: Geometry Points / Profile Geometry Points
  4. Add
Let me know if that works for you. Like you said, you'll most likely have to tweak the styles.
Happy drafting!
AUTOCAD Civil 3D 2013
Windows 7
Processor: Intel (R) Xeon (R) CPU W3565 @ 3.20GHz
Installed Memory (RAM): 12.0GB
System Type: 64-bit
Erika
*Expert Elite*
TRogers
Message 3 of 3 (437 Views)
01-12-2013 08:14 AM in reply to: accarr03
It sounds as if you are not using a template file with the required label styles.  Import the the "out of the box" template file by clicking on the Manage tab and at the far right, click on Import.  Browse to C:\Users\[user name]\AppData\Local\Autodesk\C3D 20??\enu\Template and choose the _AutoCAD Civil 3D (Imperial) NCS.dwt.
After you do this,select your proposed profile, in the contextual ribbon, select Edit Profile Labels.  Once in the dialog box, at the bottom right, select Import Label Set.  Then select the Complete Label Set.  Click OK and they will show up.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
