I have 3 versions of Civil3d on my pc (don not ask why!).
Is there a way to choose which one would be the default one starting by clicking on a arbitrary dwg?
Solved by teflon. Go to Solution.
by default Windows should start the C3D-version that was started last time. So if you started C3D 2013 last time, close it and double click onto a DWG-file in the Windows explorer the 2013-release should be started.
You can right-click the DWG-file ==> "Open with ..." and here you find the option for selecting the default application; instead of the "AutoCAD DWG Launcher" (which handles the "what was started previously") you can now select the ACAD.EXE file of that release you want to start by default.
Another option is to start C3D (whatever version you like) and do then the double-click in the Windows explorer ... the AutoCAD DWG Launcher sees then that an AutoCAD instance is already open and forwards the double click to the already running ACAD.EXE.
HTH, - alfred -
These solutions should work but they do not!
If I save a file using 2012 clicking on the file starts 2013 version!
I have some programs working only with 2012 that is the reason I do not wqant to update all files to 2013 version.
Which solutions don't work? If you open Civil3D 2012 and then double click a DWG in Windows Explorer you get that drawing opened in C3D 2013?
If you right-click the DWG in Windows Explorer, then goto "Open With ..." what is the default program?
BTW: you closed 2012 after then or was it left open?
- alfred -
Try this.
Close all acad sessions. Find a dwg in Windows Explorer and right click on it. Select Open WIth and then select Choose DEfault Program. Set the default program to the AutoCAD DWG Launcher.
John Mayo
+1. Given the number of applications that use DWG (AutoCAD, Civil3D, Navisworks, Map3D, Trueview, just to name a few), plus the different profiles available, *AND* the importance of using the correct version for the vertical products, it just makes sense to open the correct software first. Once there you don't even have to do file-open, just drag the selected files onto the command line.
I too have multiple versions and profiles for Civil 3D. I have found the only way to open a drawing using a specific Civil 3D version or profile is to have my desktop shortcuts for each version in my Windows "Send To" folder. That allows me to right click on a drawing, select "Send To" and pick the specific version to use.
Have a look at this link, it explains how to set it up:
http://www.howtogeek.com/howto/windows-vista/customize-the-windows-vista-send-to-menu/
Hope this helps,
Keith Biggs
Chair, CAD Standards Committee & Senior CAD Technician
R.F. Binnie & Associates Ltd.
Leading in Quality: OQM certified March 2013.
