I have been using Civil 3D since 2005, but have never used Autodesk Vault. Now our company is moving toward multiple C3D users and Vault will be a necessity. I am trying to install it on my Dell Precision 380 with AllinWoder 512 video card and 2GB ram running XP Pro with C3D 2007 having all service packs installed already. I attempt to change the C3D install and add project management capabilities. When installing Vault, I get the error:
Error 1308. Source file not found: C:\Program Files\Autodesk Civil3D 2007\Exporer\Connectivity.Proxies.Admin.dll. Verify that the file exists and that you can access it.
I have administrative rights on this computer so access should not be a problem. Continuing on...
I push igore from the options (abort, retry, ignore)
Message:
Error 1308. Source file not found: C:\Program Files\Autodesk Civil3D 2007\Exporer\Connectivity.Proxies.Item.dll. Verify that the file exists and that you can access it.
Ignore.
Error 1308. Source file not found: C:\Program Files\Autodesk Civil3D 2007\Exporer\Connectivity.Proxies.Security.dll. Verify that the file exists and that you can access it.
Ignore.
Error 1308. Source file not found: C:\Program Files\Autodesk Civil3D 2007\Exporer\Connectivity.Proxies.Package.dll. Verify that the file exists and that you can access it.
Ignore.
Error 1308. Source file not found: C:\Program Files\Autodesk Civil3D 2007\Exporer\Connectivity.Proxies.KnowledgeVault.dll. Verify that the file exists and that you can access it.
Ignore.
Error 1308. Source file not found: C:\Program Files\Autodesk Civil3D 2007\Exporer\Connectivity.Proxies.Document.dll. Verify that the file exists and that you can access it.
Ignore.
Ok, finally it finishes installing the Vault progarm to Civil 3D. Now I go into Civil 3D and open master view in prospector tab. I right click on projects and click "log in".
I attempt to log into localhost as administrator, myself, and other users with the default Database "Vault" when it gives me a Fatal Error: Unhandled e0434f4dh Exception at 7c812a5bh and the program exits but does let me send a nice error report to Autodesk everytime.
To let you know my goal, I would like to have the Vault projects set up on our LAN server just like our Land Projects are. Must I do something on the server first? Must I install anything on the server? If so, is there a download of just Vault because our server does not accept DVDs.
